Plasted welded a standard one, not sure if you could do the same with the CF one though unless as suggsted above you paint it black.
just scuff up the back and glue to the back a credit card or something similar that holds it together.
A credit card? Lol, not all of us are minted enough to use credit cards to peice things back together =p
personally, I'd use a plastic welder on the back, with a peice of fine wire mesh for added support. You'll probably still see the crack on the front mind.
Cheers for the suggestions, i've got myself some araldite, seems like the cheaper option and you'll never notice i dont think.
Drove ito a curb Timmay :-(
glue from the back then grind down the crack a bit and use some fibreglass, then smooth with filler
