Spongey brakes after slider change
Louis
I Park Like a C**t
My brakes seem to be spongy now that I have changed my front sliders. I pushed out the piston on the nearside caliper slightly then pushed it back in. Was a bit of a struggle getting it back over the pads and required a slight tap with a rubber mallet.
Think I have gotten air into the system somehow? I didn't remove the brake fluid cap before pushing out and in but it was literally like 1cm. Shall I attempt to bleed?
MRBILLYUK
  FF Jeden Osiem Dwa
Just bleed it , should be fine . You'd have been better off just cracking the bleed nipple open a bit so it was just weepeing out to push the piston back into the caliper, it would have made it alot easier .
Louis
I Park Like a C**t
Thing is I hardly even moved the piston out. Had been hoping to avoid bleeding as that one's rounded but ahh well. I do have stainless nipples on order but bank holiday weekend means they won't arrive :(
Will bleed it tomorrow and hopefully that solves it.
Had a proper badly seized slider which although would turn wouldn't come out the carrier. Just seems weird it's so spongy.
MRBILLYUK
  FF Jeden Osiem Dwa
i don't know why it would be spongy if the piston only came a little bit. I always clean and regrease the sliders everytime I change the brake pads . Touch would I've never had one seize yet . If you did manage to get the slider out , clean it up , wire wool and regrease . I'd leave bleeding until the stainless nipples arrive , at least if you do manage to get the rounded one out it doesn't matter if its knackered .
  PH2 172
Thing is I hardly even moved the piston out. Had been hoping to avoid bleeding as that one's rounded but ahh well. I do have stainless nipples on order but bank holiday weekend means they won't arrive 😧
If the pedal does not pump up, it will not need bleeding.
As it has been seized, there is a good chance the pads have worn at an angle to the disc and are flexing it.
Louis
I Park Like a C**t
I've already put brand new sliders in so that's no worries. Only just got this car really so going through it all step by step.
Bit of a pain really as im going home tomorrow so wanted the brakes to he working properly for the drive back. Will have a look in the morning see if I can turn it with mole grips without messing it up too much.
Louis
I Park Like a C**t
The pads are fairly new that's the thing, and not at an angle at all. Think it just needs bedding in again properly? Very odd.
Louis
I Park Like a C**t
I'll weld them onto my calipers then as it felt so much better before.
Seriously though it doesn't feel right. Was perfect before. 😂
