Squeak/rubbing noise on a Trophy
Car  Westfield, 182, 200
First of all, apologies for not searching threads, but i'm up at 5am and need an answer!
Guy at work has a Clio Trophy and has come to me with an odd noise.
There is a rubber type squeak from the front right of the car that occurs over bumps, pulled the top mount top rubber off and jacked the wheel up and can't feel any play, but then i'm working against the suspension, i sprayed silicon lube on it and it seems worse, but may be a coincidence-was too dark to check anything else. He's going away on a couple of days and needs it sorting asap.
Any ideas as to what I can check tomorrow?
​Cheers, Ian.
Finally found it-was a dry sachs damper oil seal, sprayed a bit of shock oil on the seal and the sqeak has gone!
​Ian.
