squeaking wheels
Car  Mercedes C Class Sport
My wheels have started squeaking again usually when Im driving at slow speeds at the moment. I put a little bit of wd40 on the hubs when i took the wheels off and it stopped for a day..but now its started again. When I brake it stops the squeaking.
Recently had new discs and pads fitted....Any help?
thanks
Hey,
Did you find a solution to this? I have had this problem for months. I changed my pads and discs in April and can not get rid! I checked the bearings they are ok and set properly, i have trimmed the edges of the pads and used copper grease and this only keeps the squeak away for a day or so.
Did you get any luck?
mine was due to the cv joint gaitor coming off and losing its grease. I repacked the grease in the bearing and put the rubber gaitor back on...problem solved
