Steering remote interface! Help
Would anyone happen to have a picture of the connectors on the steering remote interface attached behind the display under the dashboard of a 2002 clio?
Im about to sell my kenwood interface kit and I have two bits, one is the main kenwood interface that leads to an infra red led, power connections with a white connector block at the other side
and the other is a short connector wire that goes from a 1.5" ish red plastic connector block to a white connector bloke that would fit with the white connector block on the kenwood bit.
Now what I need to know is are they both needed for installation or is the red plastic bit to white plastic bit the standard renault part used for standard stereos?!! will post some pics up in a second hope someone can help.
http://www.adrenalinone.co.uk/remote.htmwww.adrenalinone.co.uk/remote.htm
the additional lead that im not sure about has the number CAW-72R on it, anyone know if this is a Renault part or not?!
