Steering wheel not straightening up....
Car  Breaking 172 NV676
Just had Polybushes done on the inner and outer arb and wishbones and a puremotorsport solid top mount/strut brace fitted.
Picked the car up tonight and it feels good. The tracking needs doing which will be done at the weekend.
The only problem I have is the steering wheel isn't self centering coming out of a corner, it just stays in the same place and means i have to physically turn the wheel out of the corner. (i hope this makes sense)
Is this down to the geometry needing setting up or something else??
thanks!
I didn't have this problem when I've done that to mine?? Does the steering feel stiff?
steering seems fine, it just doesnt turn itself back to centre, if you let go of the wheel it just stays there and maybe moves towards straight a tiny amount
I'd take it back TBH, sounds like they might have knocked something off? I'm sure one of the experts will answer you in a bit!!
Just been out to it and power steering seems to work fine, fluid level is on the minimum so could do with a top up but should cause problems.
