I've noticed that recently my STOP light flashes randomly whilst I'm driving, doesn't do it so much when I'm doing 0-30mph but on the motorway when I'm at a constant speed it seems to happen a lot. 2004 1.2 Dynamique if that makes a difference.
Could be low brake fluid, and the cause for that would be brake pads are low. Don't just too up the fluid if it's low check the brake pad material on the front pads.
Checked the brake fluid level and it seems fine - plenty left! I've only recently had brake disks and pads replaced (last month) so they are fine, could it just be a loose connection somewhere?
Check the thick red cable going to it first, if it has a bad crimp on it or loose, it will detect faulty charging and the light flash up... Might be a cheaper fix.
