Stupid head unit thingy wotsit
  106 GTi
Connections on the back will be ISO so it should plug straight in, but you may need a direct feed to the battery.
You will need the stalk and display adapaters if you want to keep these features working.
  Mercedes SLK350
I have the same head unit.
It is a straight swap.
What extra wires are you referring to?
No connection to the battery is required.
Good choice of head unit b.t.w. It's quality.
KDF
  Audi TT Stronic
Wow, its a self powering HU, no wonder its so expensive :clown: ;)
  Monaro VXR
its supposed to be wired directly to the battery or they recommend it is due to the 4 x 60w output.
Da
  Less
Yeah, 240w at 12V = 20 amps so pretty hefty load for the standard dash wiring which iirc is 15A rated maximum.
  Polo + Micra
120w at 12v = 20A @ 50% efficency(sp);)
  Polo + Micra
yep they use a dc-dc converter to up the voltage to 17.2v which pulls more current than the standard wiring can take safely
