I would suggest against it as it is very easy to get water into the spark plug holes - you need to also wrap everything that is electrical - i dont have to explain water and electrics don't mix lol
Cloth, or even a roll of kitchen roll, and use degreaser to wipe down all the dirt. Or do what I did and inadvertently drive into a giant f**king lake and spend 4 hours trying to clear a misfire
If your (deliberate misuse) going to waste your time being pedantic, at least get it right. Try using quotation marks instead of apostrophe's when you are quoting something next time.
possibly the single most stupid thing you can do to an engine. I'll sometimes jetwash a bay out before doing a big strip down, simply to make it easier to work on. I've seen more misfires and rusted up plugs and leads from washed engines than you'd believe
You quoted the word with a correction. Because you're a sad sack. There's no other reason to put an apostrophe before and after a word unless you were quoting it.
Perhaps you won't mind if I correct you whenever you make an insignificant mistake? You posted this earlier this morning:
