sub wiring to head unit problem
Car  clio 1.2 16V
Ive got an LG head unit in my clio and tried to wire a sub 2it but there is no where for the blue remote cable to go. My corsa has a sony head unit which had an extra wire attached to simply plug the remote cable into but the clio doesnt.
Can anybody help? I read somewhere that u need 2 attach it 2 another wire?
Cheers Ben
To a live wire that only comes on when the ignition is on.
Normally a yellow wire, just check that when the amp is off when the car is turned off. Or you'll drain the battery flat over noght.
you need to find out which is the electric aerial wire on the back of your HU and then cut that and join it to the blue remote wire. most HU's have a key on them to tell you which wire's for which.
