If you upload a picture of the parts you have it'd be easier for someone to help. I would if mine were off the car
I have TA's so should be the same.
yeah, i would, but they are kinda on the car atm, its on axle stands so theres no pressure
this is the set
the fronts are what i cannot fit, the back i think ive done correctly
from that picture i took the rubber bits off the old shock (only the rubber bit)
toook the nut off the top of the new coilover
placed the rubber between the domed top of the coilover and a big silver washer then mounted it and screwed in the top mount
if you can follow that well done, ill take some pics in the morning
this is what ive done
sorry for the diagram, i just want to get it sorted soon :/
the arrows represent the movement when mounted
as ive said i probably did it so wrong!
