Nafoff
Have you got a hair colour shot of pre build, current state and expected colour post build?
that would be unfair as since then I have had a new mrs/now wife too....
You spelt s**t wrong mate.Those welds on the hinges were just tack welds ?
? Do you know what happened to JC Weldfab Neil?
Reading the Facebook post it sounds like he has been forced to close and not by choice.
So I think the JCWeldfab name went with Jon (who was 1 director), and has left. I believe JCWeldfab as a building/location is still present now as Alpha Performance Fabrications being run by Michael (who was the other director). Not sure why any of it happened though
Great work you doing there mate. It’s a pleasure to read every time
Regarding hinges, I think the way you wanted them to attach to doors was always a slightly wrong way of doing it. They are light but not that light. No amount of weld around studs will hold them in place. I mounted mine (same as you last idea) spreader plates on the inside with nuts welded on. Drilled holes on the hinges and m10 8.8 counter sunk bolts.
Also, about how you mounted your dash.
Did you mount/check visibility while seated in the seat and steering attached? Reason why I am asking is i almost made a mistake of making nearly identical plate to mount mine. But at the last minute when sat in the seat realised that top of the steering wheel was blocking it. And there was no space up or down to shift it. So ended up mounting to column instead. View attachment 1403335this was solution instead. And brought closer to the driver for better visibility. I am sure you have seen the final result View attachment 1403338
I am 6”4’ so yeah a little taller [emoji1787]
It’s attached to column with a roll bar bracket from eBay. And a second support to prevent flex.
Looks awesome ??
What make fan is that? I’ve got that on my list to buy
Fantastic effort. Followed this from the very beginning and delighted to see you adding the final touches.
Engine bay looks soooooo much better with ABS, power steering, battery, fuse box etc removed.
I fitted a 2ltr Mocal (in black) to the inside of the suspension turret on my other Clio before we sold it. Fitted nicely there and of course decent quality. All looking good Neil.
I think the question I would ask is, is there any reason you would go for the Mocal? I think I must just be a bit cheap but, given what some of the unbranded stuff can be had for, and that it's only a catch tank, I don't think I could be bothered with the expense of a fancy one.
Gearbox mount needs a cover over it to tidy it up @Nafoff
Or some PMS race mounts @Nafoff ?
I’ll just leave this here...............I do agree. They are pretty much double the price of the Ralloy ones and they look nice too. I am not even desperate for one as it will only be initially needed for mapping - i may not worry at the moment and then put it onmy “snag list”
its not that ugly.... its bauhaus... Form follows function, ha
I’ll just leave this here...............View attachment 1404356
Yeah I know what you’re saying mate. It’s w**k that it doubled up as an ecu mounting place too. ?Don't leave that there.... I don't agree, I think that is just as ugly.... and adds weight too
Fire away mate.I get it if it had a second purpose for sure...
Just a thought and putting a finger in the air. You are pretty clued up on timing aren't you? I may pm you dependent on your answer... lol
Fire away mate.
Good progress.
I had issues getting the Renault locking tool in the cat cams too. The slot for the tool wasn’t wide enough and I had to file back the Renault tool and was still really tight to get in and out the cams.
