THE SHAKE NO ONE COULD SORT HAS BEEN SORTED AND FIXED, READ MORE INSIDE !
Car  ITB 428 Ph1
Hi
I dont know if you can remember but I had a terrible shake between 50 - 70mph threw the footwell of my phase 1 sport. The harder the accelleration the worse the shake. However if you creeped up to 60mph and held it there, the shake would go. Anything over 80mph and it would also go.
I had the wheels balanced twice by two different companies and I also was advised to get rid of my Yokohama Spec - 2 Tyres which I now regret and bought a set of p600 perelies. The car had been too many garages and no one could identify the problem.
It was up on ramps and no one had a clue. The renault garage couldnt even work it out.
However the problem has now been fixed. It was the driver side drive shaft. In the shaft there are 3 bearings. One of the three bearings has worn and was fooooked. This led to alot of play and a hell of a lot vibrating.
The garage that found it was a breakers yard in Bungay could Cit Ren. They specialise in French cars and they guy in the workshop found it in around 10 minutes. This was such a relief of my mind as I was thinking the worse and thought it would never get fixed.
If any one has this problem I hope this helps.
Cheerz Correy
Well that's a bit off matey. You were told EXACTLY what it was by many people - (one of whom is said to lactate 5w-30 when he hears an ITB'd F4R on song) - Yet You chose to ignore them, and then forked out for tires etc...
Saying "noone could sort it" and creditting a Scrappy for finding something that had already been pointed out to you is a poor idea. Especially so if you think you may require help from these knowledgeable people in the future.
Credit where Credit's due eh lad?
Just incase you forgot, Here's what it looked like.
Sorry guys, yes it was clearly brought to my attention in my previous post. However when i tried searching for it yesterday I couldnt find my post with all the help from the guys on here.
There were so many different suggestions I didnt know where to start.
Sorry again
Correy
