Toe settings 172 .
Car  clio 172 phase 2
Looking for the correct toe settings in mm . On the board at work it has the toe as -1.3 mm so I've set my NSF at +2 and the osf at -1 which makes plus 1 am I going down the right lines here ?
Would be better setting both at -0.65mm to achieve that total, or your wheel wont be straight.
Anything in the 0-1mm per side region works well on a 172 IME, just make sure the two sides are even with the wheel straight.
