Basically my cars had a deep rattle from the front left for a while, have taken off the cover under the scuttle panel and the washer that would normally be there has just eroded into nothing, so on the drivers side you can see the washer bit is fine, and the passenger side its disappeared and its this extra gap that's making it rattle. What do I need to do to fix this? Tried taking the bolt off the top and it doesn't seem to want to go anywhere but it still turns? Can I literally just buy a new washer in somewhere like Halfords and get it fitted by a mechanic fairly cheaply or is it a bigger issue than this?
The car is a 2006 1.2 MK3 clio, I've also been advised the steering track rod ends both need replacing on it because they have play and are very worn so taking it into a garage ASAP for that.
