Track Car Fuses & Relays
Car  TrackCar & F30 330d
Hope someone can give me some advice on this.
First off need to know what rating fuse, (standard Blade fuse) i should to run for the following parts.
Brake lights -
Indicators -
ECU (omex) -
Fuel Pump (omex will prob run this) -
Wiper Motor -
Windscreen washer pump -
Rad Fan -
Starter Motor -
Small electric windscreen demister -
LED Shift Light (might not need a fuse) -
Also which relay should i run for the indicators, i am going to be running a On/Off/On switch so one will be left indicator and other with be right one. Do i need 2 relays to do the flashy bit for the indicator?
you do realise that fuses are there to protect the wires
so you need to know the current carrying capacity of the wires for fuse rating
yeah the reason being is that you can't protect the components with a fuse as they are too slow
plus if the component pulls enough current to operate the fuse its already had it and needs replacing
