Trophy (Large Amount Of Pictures)
MarcB
  182 Trophy & 197 F1
Looks great Marc. How did you get the heater controls from the dash, the stage where you need to get it out of the recess and unclip the connections?
It was a pain in the arse to be honest, Once you have taken the radio out and undone the 2 screws its more or less trial and error. It was about like trying to put a square into a triangle with getting it out but once you have done it its easy. The connections are simple but its a little tight as they need to be unclipped before the unit can be taken out
Thanks for all the comments above.
Just had more work done to the car which is as follows but dont have any pictures of the work.
Replace all 4 injectors
Replace Bank 1 lambda sensor
Replace Rear caliper carriers
Replace Front discs
Replace Front pads
Replace Front calipers (Full units)
Full Brake fluid change
Replace front bottom ball joints
4 wheel alignment.
MarcB
  182 Trophy & 197 F1
Well once again another update for the Trophy.
Was at SWR getting some more work carried out on the trophy.
Here is a few pictures of the calipers from the above work carried out.
Once again the car was back in at SWR (5/10/13)
Fitted a Yanoo 1.0 Kit
Full oil & filter change
New CAT fitting kit & Clamp.
Also after being in talks with snappy i have got myself another decent wheel with good thumb grips for a re-trim.
MarcB
  182 Trophy & 197 F1
A Few Updates on the car as its been off the road.
Got Myself some 172 Sport 16" Alloys
Burst the rear brake pipe and while replacing that got a new master cylinder also
Upgraded my LED sidelights once again
The Drivers side has the new LED bulb which is shown on the left in the 3rd picture
Replaced the rear number plate bulb to a smaller & brighter SMD LED one as shown on the left
Cleaned up and refitted the correct clip rather than a cable tie
Cleaned up my calipers
Fitted a red TRS tow strap (unsure if i will keep this on)
Got myself some second hand front arch liners to fit as mine are burst
The fitted front and rear alcantara door cars to match the rear bench and trophy front seats
Got all the tyres on the 172 alloys so they are ready to go on, They have been cleaned and polished.
Also got a carbon fiber front splitter but when my bumper comes off i will fit the splitter and the arch liners all at the same time along with cleaning all the arches and at the back of the bumper and under tray
MarcB
  182 Trophy & 197 F1
Cant wait to get the front bumper off and get it all cleaned and possibly painted
MarcB
  182 Trophy & 197 F1
Small Update on the car as its not really moved since Dec 31st 2013.
Top inlet off to get sand blasted along with my spare one i have. Both are getting powder coated.
Next up the bumper was off for a few reasons.
1, To fit my new arch liners as my old ones had been all snapped
2, To clean the arches
3, To clean the front end (Slam Panel)
4, Take off the skoda splitter and fit a carbon one
Today i also bought 2 new tyres for £40 a tyre (Hankook Evo V12s)
botfch
  Clio 182
Looking good, need to do my arch liners two but the screw heads are buggered.
£40 pound a tyre pray tell?
  RB 182
Great thread and very nice trophy mate, really like everything you've done, I'd love to own one but I'm only 18 so the insurance would be through the roof, my 1.2 clio will have to do for now :)
MarcB
  182 Trophy & 197 F1
Some More Progress On The T
Needed to trial fit my Carbon splitter and sort out the fixings so done all of that last night.
The splitter is back off the car and away to get rubbed down and re - lacquered.
Also got two of the tyres off the alloys due to getting the hankooks as above.
MarcB
  182 Trophy & 197 F1
Wheels where waxed today and then the Hankook tyres put on along with new metal bolt in valves in black
  Looking the "TROPHY"
Good work done on the car, I love the TROPHY edition, I'm from Spain and this summer I'll go to UK to buy a TROPHY, I hope to get lucky with.
Greetings.
MarcB
  182 Trophy & 197 F1
Some more updates on the clio
Powder coated the top inlet, engine bracket & engine support point in silver today
  Clio Trophy
they look a lot better, but the rear bench is a gray leather, where as the fronts are black, i guess if you were really fussy u could sand them down a bit and dye/spray them black to match the fronts
MarcB
  182 Trophy & 197 F1
Well started the arches and finished them off.
Then Decided to get the Sills all sorted and undersealed due to the poor jacking points
MarcB
  182 Trophy & 197 F1
Well after 117 days of sitting on axel stands i popped the wheels on and took this a spring round the estate.
Then popped the car away ready to get the carbon splitter on and build it back up
  Clio 182 Trophy
This was a great read! Massive amount of respect for doing most of the work yourself. How do you find the AST top mounts for road use?
MarcB
  182 Trophy & 197 F1
Great work Marc. How do the side skirts come off? Need any new parts to refit?
undo the t20 torx screw in the arch
drill the heads off the 5 rivets under the skirts
left the skirt upwards
knock out the the rivets left in
refit in reversal
you'll need at least 10 4mm rivets, its really easy
http://www.ebay.co.uk/itm/271210350...eName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
As the man above says buddy
AST Topmounts + Polybush Bottom Mounts + Polybush Dogbone + Sachs = Harsh , I feel every crack, leaf & pebble on the road but it handles bloody well
