Trophy Project 40/500
when i collect the car it's going to the fabricators, seam weld the shell, weld in the door bars, add the additional bracing to the front turrets, rebuild the front turrets to take the subaru top mounts, weld in the strengtheners for a and b pillars,weld up the subframe and back axle.
After all the fab work it's going back down to be re dipped and sent off for coating, before it makes it way back up here for paint :D
When you say it like that it desnt sound too bad, that wont take long, Lol.
Did you mention how much the acid dipping was? Just out of interest like
Nice one chris, just looks like a ph1 172 in the pics with it being in bare metal (silver). Interested to see pics and more detials on the rear stubs, was something i was considering tbh as i know its been done on other cars with a similar setup.
Russ
Russ, here's a machined rear stub axle, it's been machined to a 2 degree negative camber.
Once i've built the car back up and found out the run out on the rear axle, i'll then get them machined to 3 degrees negative.
One thing to consider though, is for each 1mm you machine off the top, you'll bring the top of the tyre 10mm closer to the damper :eek:, so while camber shims may no longer be required, a straight shim could be.
It's sounds a daft way of getting the camber, but by the time you've fitted them for toe too, you'll probably get back what you've lost ;)
forgive my ignorance but would you not have to get the holes remachined and retapped to accomodate the new angle?
Love this project :) always got an eye out for updates!
Things are starting to progress now, Tuesday i collected the shell from the dippers, but due to work commitments on Wednesday, the shell just sat there waiting for attention :(
Anyway i've spent the today at the Fabricators, and we've got quite a bit done, probably 1 or 2 days work remaining.
1st off here's the shell before we started, ignore what looks like rust marks, there a combination of things, and will disappear once the shell is re dipped, then it's rust treated, and finally it goes of for E-coating.
Seam welding around the rear turrets
Front Bulkhead seam welding
Welding to the underside of the new front turrets
More seam welding under the shell
I'll get some more pictures up tomorrow as the fabrication work continues :D
This thread is just awesome i'd have loved to have known where my project was going at an early enough point to have realised how much acid dipping would've helped. Theres something so very exciting about seeing a project like this coming together so please keep the updates coming in as much detail as you like ;)
Chris,can't help noticing but the seam welding looks like its been welded all along chassis etc..
When we used to do the rally cars(many years ago)we were advised not to do this as the shell still needed some flexibility,so even it was called seam welding it was welded 2 inches leave 1 inch and so on.
Shell looks good,bet that was easy welding that with nice clean metal.
Yeah Tony, were it's welded we have fully welded it, but there is a few sections that are un welded, it's mainly been the high load areas.
We did speak to a few people about stitch welding and there seemed to be mixed reveiws, so we opted for fully welding the seams in high load areas.
Chris
Ok just that on the old Escorts the windscreen used to crack over a jump if fully welded.
Yeah i think that's were the confusion comes in, for Rally cars it was advised that weld one miss one would be beneficial due to the flex required due to the surface, lumps and bumps that the car would have to endure.
But for circuit use, i was advised that a fully seamed shell would be better, but without the need to go over the top and weld every seam, Mainly concentrate on the high load areas.
I suppose i'll just have to wait and see :eek:
Its looking good Chris,did you weigh the shell when you got it back from the dippers,if so how much did you loose.
No Paul, I never got round to weighing it, the garage is full of work gear, so i couldn't get the weighscale out :eek:
But i reckon around 20kg's has been lost in the seam sealer and underseal, by this time tomorrow, we'll have replaced that 20kg's loss with welding wire and steel ;)
Hoping to have the shell back in my garage by the end of November.
I've just done another search for the seam welding Tony, just want to make sure i've not read and been told is not duff information :eek:
It turns out what i said above is pretty true for a lot of cars, although there is now a few builders out there that fully weld rally cars :S
using the argument that flex can cause fatigue failures over time and that by fully welding the seams they have eliminated this. I suppose it could just be a case of each to their own. I know prodrive used to stitch their cars.
Looking good so far chriss, was going to say about the seam welding, i know my leon is just stitched and not fully welded. Thing is what happens if you start having issues when its back together, gonna be pretty difficult to rectify and be a shame to see the amount of work go into it be wasted, bit nerve racking.
Russ
coming along now - lovely to see the naked shell!
If that had been a mk1 clio half of it would be left in the dipping tank haha
Not Sure Jord, as far as i'm concerned white is white (within reason;)) but i think the bodyshop said they'd use a Renault white.
Looking forward to the end of next month when it will be back in garage :D
Back to the Fabricators for another day of shell preparation :D
Today was mainly a case of sealing the bulkhead from the engine bay and fit the extra cage and door bars.
1st off the bulkhead plates were welded in
Then weld in the extra cage bracing at the front
Then the passenger door bars
And then the drivers door bars (still a bit of work required with these)
And that's it for today, a couple of hours tomorrow and the car will be ready to go back for dipping again, this is a few more of how it stands at the minute.
Just finished of the shell this morning, it's now ready to go back to the dippers on Monday morning :D
Here's how it stands at the moment.
High standard of work going in here! Would look good white with red trophy decals.
Its just tip me over the edge seeing them pictures Chris:approve: ,I will look forward to seeing it all painted up in white:cool:
You have pretty much convinced me to get my new shell dipped. Just hope I don't crash it too soon.
Think the general stuff thats used is either 44.45mm x 2.06mm, or 40mm x 2.~ as you mentioned..... I know all my cage is made from the first size, cold drawn seamless (supplied by custom cages)
