Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Having read a few of the other threads im just wanting to find out where the best place to fit a return line is.
If i put it in the sump, what happens about it being below the oil level?
wheres the best place to put it in the block.
My lpt build was returned to the sump, at the highest point on the sump it is above oil level, if your returning through the block there is a flat part in the casting lower/middle of the block, if you return through the block you will need to strip the engine ideally due to swarf.
