two amps
  clio 1.2 16v expression
Im trying to wire up two amp, this is my setup so far
When I got the car amp was already wired up a 4 channel fockford fosgate p4004, but the way they done it is that each car speaker front left, right, rear left right is wired direct to the amp through two cross overs as there are tweeters aswell.
For my 2nd it’s a alpine mono amp or something to run two 15”, the amp is wired, ground power, remote etc, all I need is the RCA connection, but think is on the other amp I got 3 RCA connections going to it, front, rear and pass through, so im not sure what to connect from one amp to the other. Do I just remove the pass through and connect a lean from that pass through connection on the Rockford amp to the RCA connection to the alpine amp?
