"UNEVEN TYRE WEAR AND ITS CAUSES
Look at the tread on your tyre. Is it evenly worn right across its width? If not, it could be due to under-inflation or over-inflation, which we’ve already covered. However, if it’s worn only around one edge, particularly on the front tyres, it may be because of poor wheel alignment or other mechanical problems.
Have a professional garage check out your car’s wheel alignment and suspension; if there’s a problem with either of these you should have them fixed immediately."
