lol, knew it. Well my suspicions were your timing was out & you had piston to valve contact. Question.... after this so called map change..... did your lumpy idle go??
Have u talked to who ever did the work on the car ? Sounds like a timing problem
Yes I have, he was suspicious about something after changing belts.
He asked if the car was completely standard, as it didn't time up precisely.like what? did he say?
hmmm, sorry to say dude, looks like your failure was due to timing being out, really sorry to.
Cant see why he couldnt time it up correctly, with the correct timing & locking tools, should be fine.
tell u what could have happened, its possible he locked the crank in a balancing hole.
If what your saying is correct Mike (and all info supplied is correct), then surely it's up to the garage to replace the engine/fix the engine? As it was their timing that destroyed it.
Like I said presuming all is correct.
Sorry to hear about that OP! Last thing you wana hear I suspect
Im not pointing the finger at who is to blame etc, of course Mr Rossi, had had a firm work on the engine, the mechanic told him, he wasnt sure about the timing, and not long after due to some sort of internal failure, its gone bang. More investigation needed before a finger is pointed........
I know this, but the car is with the people I trust to work on it, which is the people that worked on it in the first place.
The mechanic asked me if it was completely standard (which to my knowledge it was) because he believed it required further investigation as something didn't add up, and he wanted more time to look at it.
Obviously now that the engine has died, and the car has been recovered there, they are saying the valve has come apart. I've no reason to not believe them.
I will investigate more when I go there today.
Agreed. it does all seem very odd, and unfortunately all of the signs to point to incorrect timing. The only problem is now, IF it did turn out to be the specialists fault due to incorrect timing, they could have covered it up by now. I know that sounds extreme and is unlikely, but you'de be suprised what companies will do to get out of things. Obviously i hope that this isn't the case!
you may have to go back and ask him what didnt add up..... the timing is set as follows, you lock the crank with a pin through the front, and to tell if its in the correct position, on the lower inner crank pulley, the slot in the pulley should be between the two webs on the lower face of the engine, then to set the cams.... pop the rear camshaft seal blanking caps out.... install the timing tool, and that is your timing set for belt removal. So you'd need to maybe ask him how he timed it up etc.
So do I- but I can't prove anything either way. So I'm kind of screwed as far as the car goes
I will try to ask him directly today.
So from that, the timing could of been off BEFORE they touched it?
Quite possibly. But surely, if he suspected aftermarket cams beforehand, he should have investigated further, knowing that IF they were aftermarket, he may well be incorrectly timing them? (with the potential to cause casastrophic failure)So from that, the timing could of been off BEFORE they touched it?
Exactly my point, timing was out, it had touched a valve previously.
Hit the nail on the head there mr Fred surely if it was timing it would have damaged more than one valve. People on here are so quick to jump on the timing band wagon regardless of the fact that these engines do s**t them selfs occasionally
This is what the technician said;
Hi Mate, I did quickly read ur message b4 Xmas and meant to reply but its been hectic with all the usual Xmas goings on. Other than the car, hope U had a good one. I'm back in on 2nd I think so until we've looked at it there's little I could guess at. Cars are complicated so taking any guess would be silly. There's always a process of elimination to work thro. Strange one tho,...i did have a few question marks over a few things with it that may have been b4 U owned it. I was just little unsure of what had been done to it previously, if anything? We'll get on in new year. Until then, have a good one.
Few things,..firstly when I plugged the laptop in to read ECU it came back telling me it was a clio V6 with different chassis number. I had to manually input the vehicle data to read memory which is strange. This could only be changed by trained personel using Renault software. When it was programmed from new at dealership it would've been as a 182. Not a major problem but an indication that someone has been in there fiddling. Also I started to wonder if it was running standard cams or if they had been changed before U had it.
When U were in sat morn, there were no electrical memory faults in ECU. **** tweaked a few settings and it was better but I still wasn't convinced it was happy at idle. So that's when I have to start thinking about the mechanical side of things. I hate Bosch plugs (they're crap and prone to missfire at high temp) so changed them for NGK and gave it back to see how U got on. If U start changing more than one thing without solid proof of fault U never actually know which was faulty. And still I wasn't happy with idle. That's when I started thinking in a bit more depth, and I remembered a comment U made about how quick it was compared to ur cosworth etc and also the cams didnt line up perfectly before I took it apart, which can be a sign they were modded as with some aftermarket cams, they have to be fitted a little off standard line to allow a smooth idle.
1. Dealers don't program f**k all.
2. VIN number is usually pulled from the airbag computer not the ecu.
3. He can't/won't have "changed settings".
4. Even if its had cams they still time up as per OEM.
Looks like it was badly written by a typical arsehole who is fobbing you off. But it's a little too much he said/she said to come to a useful conclusion I think.
only 1 valve though?
I'd be very weary and try getting someone from here to go down with you that maybe knows a bit more about the engines and the correct timing procedure.
Surely if it had aftermarket cams he could have just had a look to see what they were?
i doubt it hit just one valve to be honest. take it apart soon see.
That is written pretty badly and doesn't look very professional.
Do you know this guy/garage personally of just from previous use? Is he a friend or just someone you use?
I'd like to know who it is please? Could you PM me? I won't mention it publicly before you decide too, if you even do that is.
Either way it's a sh*t situation to be in and as said by yourself and others it needs further investigation before anything is concluded.
Good luck.
