Uprated brakes
  Clio 16v 'YOJ'
Hello all, looking for an uprated option for my clio, im using 15" wheels and as its a mk1 with 172 widetrack there's no way I can run spacers. What options are there in terms of 4 pot calipers? I really likre my williams wherls and don't really want to go to 16" wheels as tyres are more expensive too
What pads are you using?
A large number of people on here swear by ds2500 pads for fast road/light track use.
Might be worth a try? (unless you already have them in which case - I'll shut up)
  Clio 16v 'YOJ'
No its on dirty cheap apec pads and some cheapo ebay drilled and grooved discs, came with the 172 lol.
Big ash - Ouch! Cant quite afford that for my backup track car :/
LOL there you go then! 172 brakes are good!
Get some Brembo HC discs, ds2500 pads and some new DOT 4 fluid and they will feel like a million dollars.
  Clio 16v 'YOJ'
Okay cool ill spend some money on those next then, will they be okay fir everyday driving as well as track use
  Cup In bits
I have Brembo 4 pots setup for sale that fit on mk1's too but I think you'll need spacers to fit behind williams wheels. George has just done the same so best to answer.
I couldn't tell you for certain, I have a set in the garage that I never got around to fitting.
I imagine the aren't the sharpest from cold - but will be a fair bit better than standard pads when warmer.
G 172 will sort you out.
