My centre mount is knackered. From what I can see they don't do much anyway. I kept using north west performance ones but they keep braking. I'll probably just get an oem one for the centre
Joe, get them from wests renault:
Centre exhaust mount - 7700424341 - £6.77
As mentioned, they have been revised so they should be better![]()
Before I actually loose a finger, what do people cut the OEM centre out with, and trim the Powerflex bush with?
No need to spend £70 when you can get Powerflex rubbers for a fiver and get to the same outcome.
And use cable ties which will eventually break and the bush falls out , err just like the OP has stated has happened??
there are times its just worth spending the money to do it right and forget it .
Some exhausts are required to move or they can break also at the mounts otherwise, I'd check before putting solid ones in like the Prima ones, probably ok for a 172 but a 182 they have to be able to move.
More cable ties then lol!!!! DUHHHH
As long as it's free moving then it shouldn't cause any problems.
I was advised against the prima ones at the time.
Oh right, I thought prime mounts were Solid Plastic, would be handy just for the fact of having more than one hole to put the mount in.
Is there any need for the tigerseal mine feel pretty solid without it and I cba taking them off the car again.
