Urgent help required! Car won't start
Sss107
  Accord Type R
Hi all. I was travelling from Edinburgh to York, car was driving brilliantly! All of a sudden, whilst doing around 60mph on a dual carriage way, I lost all power.
I've been towed to a garage after about 5 hours!
Battery is fine, lots of 98 Ron fuel, oil is fine too. I managed to get it to start again for literally a second but that was it.
I have used a scanner and there are no faults scanned.
I'm thinking it could be crank shaft sensor but thought that this would show up a fault code?
I'm stranded at the moment so any help would be greatly appreciated!!
Many thanks,
Martyn
Sss107
  Accord Type R
Also just to add, I just done the rs tuner 98 Ron map a couple of days before. I can't see this having any effect as it was driving faultlessly for around 200 miles or so before..
Sss107
  Accord Type R
Car has been looked at this morning briefly. They don't believe it's the crankshaft sensor. They confirmed there is no fault codes either. They are off to do a compression check....
Sss107
  Accord Type R
Belts still in place?
It's *******! They were about to do the compression check.... They found part of my spark plug flying about! Was rattling in the inlet manifold..
