V6 MkII Tyre Presures
OK guys/girls what tyre pressures do you run on your MK2 Vs?
I have set mine to what it says in the manual 2 bar front and 2.10 bar for the rears, The dealer must of over inflated my tyres as they were set at 2.35 bar front and 2.50 bar for the rears, i only checked them as i noticed some unusual trye wear to the outside edges.
  Forester Sti, SC Clio V6,
not according to Renault - they used the tyres as springs as the dampers are on the bump stops if you brake and turn in a MK1!
  E91 M Sport
I have my rears on 30, and Ive noticed that the middle has worn down much quicker than the outsides - is this normal for the V6, or the sign of an over inflated tyre?
  Audi A6 (S3 on order)
or maybe its you powersliding too much ;)
Shows they are slightly over inflated.
Pressures given above are for a full complement, 2 people on board.
Also can depend on the type of journey.
Mine are mostly on the motor way and I get a fairly even tread wear both back and front.
Back last 12k and front 24k.
All with the above pressures for the Mk 1.
i run all 4 tyres 0.1 bar above manufacturers .. back end is a lot less squirmy at these pressures. Wear is still unifom too
Mike T,
Thats over 48k.
6 miles onto motorway, 125 of motorway and into office.
Saves on tyre wear.
Pads due for change to-morrow after 48k, not bad.
All the best
John V6
