Valver Springs on RT?
Car  500bhp Scoob
Just wondering whether this is possible, I'm sure it is.
Reason being, is that a friend of mine has a clio which had a snapped spring, changed it for one of my old standard RT ones, but I dont think it matches his Ph3 springs, and we cant bolt the suspension strut on now.
If its possible, how much would it lower the car?
All the springs SHOULD be the same on the base model clios.
How won't it attach to the car.
16v springs will fit and iirc its about 20mm give or take lower, prolly a hihger pounbdage as well, to allow for the heavier engine
The shock when in place doesnt match up at all with the hub assembly bolts. And when pulling down on the wishbone to try and make it fit, It ends up pulling the inner gaitor too much (caused loads of gearbox oil to leak out, and had to put a new clip around the gaitor)
