Viper from old clio to new 1.2 16v
Car  Cupra K1 & Clio 200
Hi, ive got a viper induction kit to fit my 1.2 8v (mk2 ph1), do i need an adaptor to fit it to the 1.2 16v (mk2 ph2 03plate)?
ive had a look around and it seems like i will need an adaptor plate? anyone know where i can find one of these?
Many Thanks
Hon
you need the backplate to connect it yes then possibly just a rubber shim to adapt your viper to the relevant size (60mm) you can then run 65mm ducting from the end of the viper to wherever its going.
adapters can be bought from a good motor spares, or ordered directly from piperx etc. alternatively someone on here might have one spare :)
you would be best contacting Pipercross about this, its highly unlikely someone else will do this part on its own
ben_p had a spare one last time someone put a 'wanted' otherwise you'll need to ring k-tec (as they do their own kits) or go directly to a company such as pipercross.
Ben had a plastic one and an ally one.
I got the plastic one off him, not sure what happened to the other.
