VVT/CAM question - Newbie
Ok so I don't currently own a Clio however i am doing some research for a future project so just reading up on a few things and had a question about the dephaser/VVT/upgraded cams.
So my question is, if you install say Catcam 423 for example does this cam work with the VVT system or does the VVT system (dephaser and solenoid) need to be removed and an adjustable pulley installed?
I've seen some posts saying non VVT cam and others saying works with VVT so a bit confused.
I've looked on Catcams website and it doesn't say for VVT or not.
If there is an option for both applications if so what do people recommend?
TIA
Cheers for the link.
So whats peoples preference when using an uprated CAM?
VVT delete or keep it?
What are the pro's and cons etc
