Renault wont tell me at what rpm the vvt is activated, and at what rpm it deactivates if thats different. Also, Ben believes vvt advances the inlet by 16 degrees when activated.
If anybody has that info and can confirm Bens number pls let me know. Reasonably urgent...
cmon people, I need some "exactitudeness" here, so far I have 16deg is about right and vvt activated at somewhere between 2100 and 4000. Also had a previous at 1500.
Can somebody tell me definitalytotallycrossmyheartnhopetodie what the numbers are!!!
ok having read everything on this forum about vvt, consensus seems to be its activated at 1200-1500. Nothing on the actual advance though, so the only data I have on this is bens 16deg advance on the inlet cam.
i have. I wanted someone to confirm the 16degrees inlet cam advance as Ben hesitated between 13 and 16, prob 16, and yes Ben knows a thing or xxx about the F4R engine!
16 deg, last time i had lost the tables and diagrams i made from measuring.
I will double check again tomorrow if you PM me to remind me.
VVT kicks in at about 1500rpm.........basically the cam is phased whenever your on throttle, and depehased at below 1500rpm and when your off throttle for emmisions and fuel economy.
the 5000rpm dip is the cam comming on.
If you really want to check, get a multimeter and rev the engine slowly, record when the actuator gets its 12V supply.
