Was All Going Well Until....!
Ok I snap engine mounts on gearboxs after a owning the car for a week so here goes:
New Gearbox, Clutch, Clutch Cable, Few Gaitors (Sun Roof Sorted Next Wk) 17" Alloys (Going Cheap One Day Couldnt Missout On)
Think To myself this motors turning Bk into a minter
Then I realise theres knocking coming from the car cant find source. So I take passenger wheel off & the bloody hub bolt is loose & so is the brake disk. I tighten up then a few miles later it knocks again then I check it & its loose.
Anyone help with this problem........?
  clio 20v
its a nyloc hub nut , might be well past its best, u getin any rumbling from the bearing or is there any play in the wheel when jacked up
if so bearing is shagged but try a new nut first
adi
Yeah its definately the hub nut. I had the same problem with mine. There about a £1 from Renault but because mine kept coming loose it shagged the bearing so i changed that aswell.
Dazz
P.S i know the feeling about the engine mount going and taking the gearbox with it mines just done the same. Thing is i only changed the box about 3 months ago.....DOH
Ill try the hub nut first. Is this a common problem the engine mounts cause I dont want it to keep breaking, because its a pain in the arse to fixs
