Washer pump
  Monaco 172
On a 172.
Pain in the arse to change?
Checked fuses, all good. So the motor must have gone right?
  BMW M135i
Most probably does the rear wash function not work either? Not too hard to change the pump at all but you'll need a bearing puller to get the wipers off the splines without a doubt.
  Monaco 172
Nope, no rear wash either.
Ive got a puller at work.
So, its just a case of wipers off, scuttle panel off then its under there?
Cro
  Meg'd r27
Yeah exactly that and then the pump either pulls out of the side or straight up (two designs) make sure theres no fluid left though
  Monaco 172
But other than getting the wipers off which shouldn't be too much trouble with a puller it cant be that hard!?
  BMW M135i
Nah you'll be fine with a puller but they'll be on tight especially if they've never been off before!
  172 gone :( 197 now :)
Yeah best to do it yourself mate a garage messed up my whole scuttle panel and broke my wipers doing it few months ago. Wish I'd done it myself now!
  BMW M135i
Relay? Can't get to the diagrams at the moment so I can't tell you where it is either i'm afraid.
  BMW M135i
I lied managed to find a copy, no relay involved its powered directly from the stalk its powered from fuse F3 which is a 15A in the passenger compartment fuse box. Could be the stalk, if you disconnect the wiper stalk plug and ground pin B1 and give a 12v feed to pin A4 then the pump should run assuming the wiring isn't broken somewhere.
  Monaco 172
Mate, Im a first year apprentice mechanic you'll have to dumb it down a little I'm sorry!
Thank you for this help, much appreciated!
  BMW M135i
Basically if you take the top off the steering column shroud (the one that just pulls off) you should be able to see the plugs that connect to the stalks lighting on one side and wipers on the other. If you disconnect the wiper plug on the loom end it should be numbered and lettered row A 1,2,3,4,etc row B 1,2,3,etc.
The two that the washer motor is connected to are pins B1 and A4, now you can either chuck some volts up its ass and see if the pump runs or more safely and if you've got a meter test to see if you can pick up the pump motor down the loom and see if the contacts on the stalk close at the stalk end. Should find your problem as you'll test the only two bits of the circuit really.
If your not a million miles away I don't mind having a look, revel in this sort of stuff :eek:.
  Monaco 172
Right, a little bump on this. I havent had the chance to get the miltimeter on the go yet (been mad busy in work).
Ive just been poking around the wiper area today and found this plug just disconnected and shoved out of the way all wrapped up.
Is this anything to do with the wiper/washers?
  Skoda Fabia vRS
if you have tried a new pump then id go for relay
*if* the washer pump is controlled by one of the 3 black relays in the box then try switching them around, not sure if it is on a relay or not though
