weird electrical problem in direction indicators
Car  Clio Sport 172
hi all, hope you can help me with my problem !!
with all the fuses in, i always have the left side indicators on (even the arrow in the cluster) , even with the key out of ignition !
if i click the central lock on the key, the central lock fuse burns 😧
but without the indicators fuse on, central lock works fine but i dont have indicators (obviously lol)
sure there's a problem in the indicators circuit but i still havent found it.. does anyone had this issue before??
i've even took out UCH and with the relay in the place (without uch) the light will go on..
thanks :smile:
thanks for the tip ;) clusters in the rear are out, the side ones too... in the front i disconnected the indicator plug, problem continues.. :| the arrow on the instrumental painel still lit :|
