What Am I Looking For?
  Clio Extreme 1.2 16v
I bought myself a new headunit a couple of months ago and today when i went to wire up my sub and amp i realise that there was no connection in the back of my headunit to connect the wire from the amp into? So i am now looking on the net for a new headunit. What do i have to look for in the spec to insure i get a new headunit with an outlet for an amp wire?
For example i seen this headunit:
http://www.caraudiocentre.co.uk/product.asp?product=21453
Does it have an outlet in the back cause in the spec it say "Rear/ Sub Switchable"
Please Help!! :dapprove:
  172
you dont have to buy a new hu,you can buy a line output converter,you will lose one set of speakers but save on a new hu
yeah i was at halfords tonight and they showed me the adaptor. they said i will lose either my front or rear speakers and i may have problems with interferance through my sub. Never thought at the time when i purchased my headunit to see if it came with the pre-outlet. Just thought all headunits came with the outlets :eek:
Also if a headunit only has 1 pre-outlet do you have to get an adaptor to fit the 2 connections that is on the wire from the amp?
  172
if your on about the phono leads yes.you wont get interference itll just be harder to set your sub up as it will have to be done through the amp so need a good quality one
