What Brake Lines for 172 cup
  Dodgy one
IIRC it was the earlier exact ones that had a problem with fitment BUT all you had to do is remove the clip that holds the lines secure and use a cable tie instead
  Clio 172 Cup
Am sure on the HEL lines you get Stainless Steel fittings as standard, extra on Goodridge (or that was the case when I bought mine about 5 months ago).
-J-
  RS2'ed 172 Cup
So Avoid the Exact lines basically and all should be ok :)
Any Fluid reccomendations? CL Dot 4 ok?
