what is the biggest wheels spacers people have on their cars???
Car  alien green rs133
im just curious how big you can go on wheel spacers, i have 25mm spacers on the front (between hub and wheel, with extended studs using nuts) and 30.5mm spacers on the rear :o (between the rear drum and rear swing beam) and they dont rub :o
i used to have a s****y fiesta, with 10mm spacers on, and wide alloys... im not proud of it.
didnt like them cus it changed the whole geometry of the car and shook it to peices at anything over 50mph. the amount of thread on the bolts was a bit scary too, i think the nuts only managed two turns before they were tight lol
i had 25mm hub centric spacers if you are looking at getting big spacers it is best to get hubcentric because they bolt into the hub and then the wheel bolts onto the spacer much safer then extended wheels bolts :)
