What Part?
_WILL_
  172 Cup
Altenator belt started squealing, only changed it the other day so thought it just needs to be a bit tighter. Had a look and noticed the nut that is ment to tension the belt was missing (10mm iirc). Didn't think it was to much of a problem until I realised the bolt it is ment to be on was also missing.
I found the bolt. I think it is ment to be fixed to the clamp part (the 13mm nut tightens the clamp) but it has snapped off. Its a pretty easy fix I think, belt off, alt out, replace the part and refit. Problem is I have no idea what the part I need is? Any ideas what its called or a part number so I can order one?
THE CAR IS 172 CUP, think it makes a diffrence!
Cheers,
Will
LiamR172
Scotland - NW
Bumping here but I need this part now too. Anyone know where I can get one?
Same problem as OP, 10mm came off the threaded bar/tensioner, 13mm came lose and fell out so put new nuts/bolts in but the threaded bar part has snapped now so no tension on the belt and need to get to work tomorrow which is a 4.5 hour drive! :l
LiamR172
Scotland - NW
Number 1 is the 13mm. The part of the altenator that the 13mm goes into has broken so instead of being an O shape it's now a C so the 13mm keeps sliding out of the hole causing the tensioner to come lose.
Can anyone tell me where I can get replacement parts or if there's anything else I can do as a bodge at the moment to get some tension into the belt?
Cheers.
