Hi All, yet another thread...
Ive been looking at all sorts of clios lately and Im still undecided whether to buy one thats had all the mods done as I wouldnt know where to start or start doing bits to improve the van?
Here is the van specs as per the ebay listing, what would you do next?
Phase 1 Clio F4R 2.0L 16v engine, Rebuilt and setup by Mick at Diamond motors with new Genuine Renault VVT dephaser, cambelt kit, water pump, all seals and all solvent cleaned.
NGK Iridium plugs.
Magnacore 9mm Competition leads.
Ceramic heat wrapped alloy filter relocation with RamAir filter.
Very good Phase 1 172 gearbox.
Phase 1 172 Subframe.
Phase 1 172 Steering Rack (quicker from lock to lock).
Phase 1 172 lower arms.
Phase 1 172 Hubs
Phase 1 172 280mm discs, callipers, pads and hoses.
Phase 1 172 drive shafts.
172 manifold with larger phase 1 cats with single lambda.
Phase 1 RS Tuner mapped 172 ECU, UCH and key decoder.
K-tec / Tiger 2.5" Stainless steel side exit exhaust (exits under side loading door)
Polybushed Phase 1 172 dog bone rear mount.
FK Fully adjustable coilovers on the front, dampening and height.
Torsion bar adjusted on the rear with shorter Mk1 Megane F7R Shocks. (Around 100mm drop all round)
Custom wiring loom.
Phase 1 172 dash clocks conversion including trip, MPG etc all working.
Battery relocated to the rear in a battery box on the near side.
Adjustable camber up front.
Phase 2 Clio Dynamique 15" alloy wheels with 4 brand new Marangoni Zeta Linea tyres (195/50/15).
What does this mean?? Phase 1 RS Tuner mapped 172 ECU, UCH and key decoder?
Thanks in Advance :lolup:
NGK Iridium plugs.
Phase 1 172 Hubs
Custom wiring loom.
