Wheel bolts for ET 35 wheels
Car  clio sport 200
After a little advice just picked up some pro race 1.2's 15inch ET 35 after a little research I see you can't use the standard bolts. Seen a few sets on eBay but I'm not 100% sure on what to buy, please correct me if I'm wrong M12 1.5 34/35/36mm long. Any links would be helpful
Yeah, that's nowt to do with offset, all to do with spacers.
Edited to add, I've run et35 wheels on the same car with the same bolts as et4* wheels.
The offset simply refers to where the bolts sit in relation to the width of the wheel.
The wheel groove where the bolts go is still the same depth from there to the hub. It's the surround area that's enlarged.
The bore is the standard length with a 60 degree taper to take the standard wheel bolts.
They'll all be the same across the board, it's the surrounding area that will be increased, not the bolts groove itself.
