Wheel fitment advice needed!
I have someone interested in buying my old wheels.
They are 16x7.5 and ET25. I removed them from a 172 cup and noted they had 5mm spacers on the rear
The potential buyer has a mk3 clio and the current wheels are 7j and ET35
Can anyone advise if my wheels will fit the mk3 (either with or without the spacers)?
I've had a quick search but it's too late at night to start trying to understand offset!
Yeah they will fit mate, the offset will make them sit a lot closer to his arch which means he might only need 10mm spacers on the back but it will fit fine as long as the wheels are 4x100 with a 60.1 centre bore (or bigger with spigot rings). Hope this helps mate.
Your wheels will sit 16mm (+-1 or 2 mm) closer to his wheel arch. Depends if he has 16mm room to play with
