which damn wire?
Car  182 cup
Hi guys
I'm trying to find a 12V switched power (~5A ), i'm not bothered whether its in the engine bay or in the car, just peeeeeease help me find one.
thanks Peter
to make things a little easier to understand i'm trying to connect a Aqumist into a 182
it's doing my head in:cry:
I know it's down to me being a dumb ass but it's just 3 wires that are giving me the heebie jeebies.
1. 4-way Power-in connector:
- Red ................ Switched 12V (IGN SW#2)
- Black ............... Chassis ground
- White .............. Chassis ground
- Purple .............. Head lamp switch (optional)
2. Signal to the yellow RJ45 connector:
- Red ................. Ignition switched 12V
- Green ............. Fuel injector (-) pin would this wire go to pin 59, 60, 89 or 90 my ECU are the ECU pins positive or negative
- Blue ..................MAP sensor (optional)
any help would be appriciated
it's going to be easy in the engine bay as that's where the battery is
find a switched ignition to trigger a relay and your away (another relay in engine bay?)
