which mk2 clio uses.........
Paddy_g46
the exact same callipers as a valver? i know soem of the mk2's have the same part number, also wud the carriers b the same?
All the 16v model use valver/williams front brakes I believe. Think the 1.2 8v has some from somewhere else.
Mk2 ph1 1.28v uses solid discs, all mk2s with vented discs use valver calipers but not all use the same size carriers, mk2 ph2 1,216v and above do though
Mk2 pahse 2 in 1.2 16V/1.4 16V/1/1.6 16V/dci all use the Valver calieprs and disks.
The 1.2 8V can use the 239mm disk and different calipers but there not that common anyway.
