Which Wiring Kit?
Car  Renault Clio 2003
Do you mean something like one of these for a distributor block?:
http://caraudiosecurity.com/shop/product/products_id/2758.html(just an example)
I'd have thought for the power cable, if you lay a 4AWG cable from the battery to the amp now, then when you later add another amp, use one of those distributor blocks, and split the 4AWG into to 8AWG to power the two amps, obviously both with their own ground wires.
I could be wrong about the thickness's you need though!
