Will these coilovers rub with 17"alloys?
  Clio dymanique
will fk high sport 40-70mm (54mm) coil overs fit my 1.2 16v clio 04?
And will i be able to lower it at least 40mm with 17" alloys on with out rubbing?
  Mustang, S13, AX GT
depends on how low you go. i had them on but needed 5mm spacers on the front. it rubbed a little bit on full lock but was otherwise fine. if you put them to the bottom and remove archliners you shouldn't have any problems at all
  Clio dymanique
oh ryt won't go that low, what was the hub spacing on youer car.
and is your car a 1.2 dymanique?
  Mustang, S13, AX GT
They were the same kit but I cant remember what the hub spacing was. Sorry mate, its been almost a year since i had my clio
  Clio dymanique
mine is 04, just measured and its 58mm. so just ordered the fk highsport 58mm coil overs. Hopefully get -50mm with out rubbing (fingers crossed)
