will fk high sport 40-70mm (54mm) coil overs fit my 1.2 16v clio 04?
And will i be able to lower it at least 40mm with 17" alloys on with out rubbing?
depends on how low you go. i had them on but needed 5mm spacers on the front. it rubbed a little bit on full lock but was otherwise fine. if you put them to the bottom and remove archliners you shouldn't have any problems at all
