I bought a Williams Clio 3 last weekend and the clutch is almost unbearable to use.
The clutch is heavy at the mid point - so when you put your foot on the clutch, the first 1/3 of travel is smooth and easy, then the middle 1/3 of travel is like trying to depress a house brick, then the final 1/3 to the floor is loose.
This isn't a huge issue until you try to pull away from traffic lights etc when the clutch returns with such force that the car lurches forward and the clutch engages with a bang, despite having your leg braced ready for it to happen.
The clutch was replaced with an unknown new one about 18 months ago, as was the cable. The clutch pedal assembly and self adjusting mechanism was also replaced at the same time.
I've tried lubricating the cable, and the connection on the gear box but it's no better at all.
Any ideas?
Any ideas?
