You might aswell buy one already done,i think nick at hillpower has got a williams lump knocking about id have it rebuilt first or atleast stripped down checked and new gaskets, water pump,tensioners etcQuote: Originally posted by Plattsy on 22 July 2005
tbh i didnt think it would be that expensive! think the fitting price is wrong though i did get quoted £150 for an engine fitting if i supplied all the parts.
I was on about the intake manifold there no way youd get the normal bonnet on over that.Quote: Originally posted by Rich1.2 on 22 July 2005
you dont need a new bonnet at all btw! the manifold does fit under and the purpose of the bonnet vent is to let some of the heat out!
Since you have coilovers you can use normal o the shelf springs. Demon tweeks sell them for £50 for a pair. Almost any weight you want.Quote: Originally posted by Rich1.2 on 22 July 2005
ill be running valver lowering springs an it for now until i have the ££ for proper uprated ones.
the normal bonnet fits the same as a valvr one but the vent part is just raised up it fits no different and isnt any higher
Quote: Originally posted by JayR on 22 July 2005
Your lookin at alot mate!!!
Mine was a good price at Just over £1600 for a 45k engine, recon willy box and some replaced parts such as cambelt, clutch etc!!!
Id say 3k would be a good price into a 1.2 shell............Deffo worth looking into buying the bolder looking hybrid valver or williams id say!!!
BigChriss one looks in good con and by all accounts a fast one aswell............Only 3k!!!
BigChriss is a beast, i had the pleasure of picking it up for him from GDi a couple of weeks back, and its defo faster then my standard Hybrid, the extra torque is amazing too in comparison.
£3k is a steal and if it was mine id ask £4k for it and wouldnt budge.
My conversion cost a little more in the end as i opted for the donor Williams3s complete interior too, even suit carrier, top dash, clock, heater dials etc
std bonnet without the bulge fits over the F7P/R engine no problem.Quote: Originally posted by edde on 22 July 2005
Id recomend running highter poundage front springs though say 200lb.
Probably hits once the engine starts moving up/down.Quote: Originally posted by number1 on 23 July 2005
When i fitted a standard bonnet to my valver it cut away at the inlet manifold which was rather deep.
Dave
Id go with the Williams a 1.8 will be only slightly cheaper say £250 Vs 750 so there only £500 difference since a 1.8 youll still want to change all the belts etc and instalation cost is the same.Quote: Originally posted by Plattsy on 23 July 2005
thanks for all the feedback, i will probably modify the standard bonnet as i want to keep the standard 1.2 look. i may end up dropping to a valver engine as i know they can be picked up alot cheaper and possibly upgrade in the future. that a better idea? dont quite fancy buying a new car just yet, perhaps next year.
Quote: Originally posted by stan* on 23 July 2005
it helps cool the exhst manifold area really....heat "release" only occurs at standstill
naturally if u were to use the non-16v bonnet u would fit some sort of vent
But dont you get a ram air effect pushing all the hot air within the engine bay out the bottom of the engine while moving
Yep.. that little bit extra, makes quite a difference.Quote: Originally posted by Martin. on 26 July 2005
Williams track is deffo worthwhile..
