Williams/megane clutch
Are they the same.
I've been searching for a clutch for my megane engine and gearbox and the megane clutch is listed as being 215mm and the williams as 200mm.
I know people have used the uprated 5 clutch from GSF foe valver engines but will it fit the meg
Any advise appreciated.
Ian
If using a Megane BE you have to use the Clio flywheel. So if the flywheel is different I assume the Clutch is also different.
Just get Megane clutch from GSF.
Don't think the gearbox will fit fella...mounts are different IIRC.
If it does then yeah, you could use a megane one. Fairly sure a williams/16v will fit that engine and gearbox combo too as long as you have the matching flywheel.
