Hi all, thought I would do a write up on my Turbo'd Williams.
Have got a rather unorganised project thread on c16v but thought I could update and neaten it into a new thread for (hopefully)more people to appreciate.
So to start a history of WAM
Bought back in Feb 2011 as my first Williams after wanting one for ages. I decided to bite the bullet and come away from the 16v's and go for a proper clio.
Ive had around 10 valvers over the last 5 years so the idea behind the williams was to fit my turbo engine I had been building to it.
In November 2008 I gave my F7R to Craig at APD with the intention of a standard rebuild. Well one thing lead to another, found some parts and ended up going low compression! Much to my bank managers disgust.
I went pretty OTT on the spec and made sure I had everything needed to go all out in the spec department. At least then I wouldnt regretnot doing it later. Anyway some pictures
Block
Lightened crank
Wossner pistons
Forged rods
Tickety turbo
Trying to cut a very very long story short I had alot of very new parts I had bought brand new over the years for my valvers.
The Williams, being my new baby, got whatever it wanted. So...
285mm Hi specs
New wishbones, bushes, newARB
Ive always been the kind of person who regrets not doing things properly the first time. So I made sure I went to a good spec.
Catcams turbo spec cams]
Gas flowed head
GT28RS60 Turbo
Lightened crank
Lightened 172 flywheel
Helix four paddle
33mm valves
Vernier pulleys
Uprated cam springs
So basically went as far as I could go without doing silly money.
Gas flow
Shiney things
My next port of call was receiving the engine backafter a solid 2 years with Craig...
Getting it built up on the stand was a great feeling
Fitting new JC5 to it
Luckily I had done all of this 100 times before so it all came naturally!
Once it was all mocked up,newbolts bought for the turbo, new manifoldstuds from renault I torqued it all up and got it ready to stick in the car.
In
Cooler mocked up
Ghetto ramp
Getting there
I had decided to go down the standalone management route. Basically I couldnt help thinking thats getting the car chipped was a bit of a bodgey way of doing it. Sorry to anyone that has.
So I ordered a part made loom (to help me a bit) and an Emerald K6 ecu. (which, btw, is the coolest gadget I have ever had)
After a few niggles with the loom were ironed out, I got the car cranking and everything reading right... basically got a chap downwho knows his Emeralds and we couldnt get it going.
Disaster, no compression. 40psi across the board.
As you can imagine. 2 1/2 years after paying alot of money for an engine and still not having a working one really hurt my feelings!
Back to Craig it went. Somehow the valves were getting stuck open and for whatever reason it kept knocking the timing out. So basically Craig put some different tensile bolts inand 16 new catcam valve springs. (another 800 odd quid!)
Finally the car came back to me (running).
Having now completed everything in terms of the build, I am waiting for mapping on the 6th.
The engine drives super nice, its a bit glitchy with the unmapped ecu but apart from that theres nothing major left.
Havnt even been allowed to let it boost yet, but ATM with less than 40% throttle allowance and my wastegate wide open, its actually quicker than a zetec s. Lolz
Figures to come on Friday!
thanks for reading even though it wasnt massively entertaining. Ive used language my Nan wouldnt be proud of quite a few times!
Block
Lightened crank
Wossner pistons
Forged rods
Tickety turbo
285mm Hi specs
Gas flowed head
GT28RS60 Turbo
Lightened crank
Helix four paddle
33mm valves
Vernier pulleys
Uprated cam springs
Gas flow
Shiney things
In
Cooler mocked up
Ghetto ramp
Getting there
