Wind deflector and side skirt issues
Car  182FF
Anyone have a quick fix on how to stop the window catching this corner?
As you can see this set has had a little chunk taken out of it.
Next problem.
Is this just a simple case of tightening a bolt or do I need a new skirt? Can't see anywhere to tighten it up.
Thanks. Sam.
Do you have the clips fitted properly with your hekos? I found that when i didn't have the channel clip in, the window clipped that corner until it snapped it off. It still operates as intended though.
As for the skirt - i think there are clips or something the skirt sits on, maybe check they're tight and fitted properly?
Yes with regard to the wind deflectors both clips are in place... It catches but only just.
The side skirt will need more investigation when the weather is not so bad.
